How to test Qos is working or not
I have a c2950 switch and have configured QoS for VoIP.
Basically:
1. fa0/17 set to default cos 5
2. fa0/18 have input service policy.
How can I test using 2 XP clients connecting to these 2 ports to test out QoS policy. The show commands seem to show what policy have been configured and is not what I wanted to see. I want to see counters showing QoS is working or appications running to XP to show QoS is working
I have attached a simple configuration of c2950 below.
Thanks and rgds.
Switch#show run
Building configuration...
Current configuration : 3694 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 3
wrr-queue cos-map 3 4
wrr-queue cos-map 4 5 6 7
class-map match-all VoiceControl
match access-group name VoiceControllist
match access-group name Voicelist
policy-map 2950-LAN-Edge-In
class VoiceControl
set ip dscp 26
class Voice
set ip dscp 46
mls qos map cos-dscp 0 8 16 26 34 46 48 56
ip subnet-zero
interface FastEthernet0/17
description To XP/IP phone
switchport access vlan 29
switchport mode access
no ip address
mls qos cos 5
spanning-tree portfast
interface FastEthernet0/18
description To XP/Gatekeeper
no ip address
service-policy input 2950-LAN-Edge-In
interface Vlan1
ip address 140.231.117.1 255.255.255.0
ip helper-address 140.231.117.15
no ip route-cache
ip http server
ip access-list extended VoiceControllist
permit tcp any any
ip access-list extended Voicelist
permit udp any any
line con 0
line vty 5 15
end
1 REPLY
Bronze
Re: How to test Qos is working or not
Here are a couple links that are helpful in determining if QoS is working:
click on "Verify and Troubleshoot"
http://www.cisco.com/warp/public/788/voice-qos/voip-ov-fr-qos.html#veri
The quickest way to verify QoS, is this command:
show policy-map interface serial interface#
Here is an explanation of this command:
http://www.cisco.com/warp/public/105/showpolicy.html
NOTE: remember that the values will ALL be zero in your policy map until you saturate the link. (the link must be saturated in order for QoS to engage).
595
