How to upgrade flash on a MFSC2
hgru
We just replaces a Supervisor2 with an MFSC2 in a 6500. Now the replacement has less flash so I want to remove the flash memory from the old MFSC2 and put it on the "new" one. Now on the old oen I see twee Sims. which one is it or are they both flash? Do I have to do something extra te get it to work?
hgru
Got the answer from TAC :
Take a look here and replace the other dimm that is not DRAM.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_6953.htm#wp20275
