Community Member
how to use default route achieving load-balancing?
show me an example
thanks
1 ACCEPTED SOLUTION
Purple
Re: how to use default route achieving load-balancing?
Try this:
ip cef
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Serial1
With the above config, the router will perform per-destination load-balancing. So for example, a session to IP 10.1.1.1 may go over Serial0 while the session to IP 192.168.1.1 may go over Serial1.
Pls do remember to rate posts.
Paresh
Hi Friend,
If you have 2 default route with same admin distance you can have equa load balancing.
Something like this
Now because these 2 default routes have equal admin distance so both will be peferred and will result into equal load ballancing.
HTH, if yes please rate the post.
Ankur
Purple
Try this:
ip cef
Paresh
112
