Webcast-Catalyst9k
How would Centrex Data Circuit connect to ISDN
I have Central site with one ISDN (2B+D) Circuit. I have two remote site one with ISDN and other with Centrex 56K Data Circuit. Following is configuration of Central Site and one of the remote site with Centrex Data. Why can't they connect to each other ?.
Central Site Configuration
interface BRI0/0
ip address 192.168.0.45 255.255.255.252 secondary
ip address 192.168.0.37 255.255.255.252
no ip directed-broadcast
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer idle-timeout 1800
dialer map ip 192.168.0.38 name PPPP XXXXXXXXX
dialer map ip 192.168.0.46 name XXXX YYYYYYYYY
dialer-group 1
isdn switch-type basic-ni
isdn spid1 XXXXXXXXXXXX XXXXXXX
isdn spid2 YYYYYYYYYYYY YYYYYYY
isdn incoming-voice data
no fair-queue
ppp authentication chap
hold-queue 75 in
Remote Site Configuration
interface Serial0/1
ip address 192.168.0.46 255.255.255.252
encapsulation ppp
no ip mroute-cache
1 REPLY
Anonymous
N/A
Re: How would Centrex Data Circuit connect to ISDN
Sounds like your remote site is a
sync 56K serial connection (ie up and
clocked all the time), and not a dial
on demand circuit. If that is the
case, there isn't a way to allow the
central site to connect to both a
remote ISDN user and a remote serial
user.
You should check with the carrier to see
if they can setup the Centrex for out
bound dialing, and then configure the
remote for DDR.
109
