Webcast-Catalyst9k
Silver
HSRP and EIGRP. Do I need MHSRP?
Please draw as you read. It may seem complex but is a very simple problem.
EQUIPMENT:
PIX with 2 interfaces,
12-port Switch (Sa),
12-port Switch (Sb),
RouterA (Ra) with 2 Ethernet and 1 serial interfaces,
RouterB (Rb) with 2 Ethernet and 2 serial interfaces.
CONNECTIVITY:
Sa and Sb connect to each other
Sa connects to E0/0 of Ra
Sb connects to E0/0 of Rb
Pix's outside connects to Sa
Ra and Rb are connected using cross-over via their E0/1
Ra's serial port is conencted to Site A
Rb's serial port 1 is connected to Site A and serial port 2 is connected to site B
Both switches and Routers are outside the firewall.
IP and ROUTING:
Ra and Rb run EIGRP with remote routers that belong to someone else. All routers are in the same AS 1.
Site A is one network say, 10.1.1.x, Site B is another network say 20.1.1.x. Both connect to each other as well, for redundancy, forming a typical ring with my outside routers.
QUESTIONS:
Q1. Should I define two HSRP groups so that my PIX gets two outside gateways and sends data destined for Site A to Ra and data for site B to Rb.
Q2. If I only define one HSRP group, wont EIGRP anyways direct all traffic destined to SiteB to Rb?
Q3. Is there any advantage I will get if I decide to run MHSRP or I am just making my network unnecessarily complex?
Thanks.
1 ACCEPTED SOLUTION
Silver
Re: HSRP and EIGRP. Do I need MHSRP?
ANSWERS:
Yes. No reason not to and no reason to incur extra hops which are not needed.
Yes. Assuming you have configured EIGRP correctly.
Yes (to 1st 1/2 of Q). Reduced router loading (no handling of packets unnecessarily) and higher performance (eliminate delay introduced by the extra Ethernet hop).
Yes (2 2nd 1/2 of Q). Assuming links are T1, you won't be able to measure the difference.
You're welcome :-)
Vincent C Jones
www.networkingunlimited.com
1 REPLY
Silver
ANSWERS:
You're welcome :-)
Vincent C Jones
83
