HSRP and ip addresses
Just want to make sure I got this right
when using HSRP I need to use basicly three ip addresses in the same IP network, i.e. one address on each HSRP device, and one for the virtual address.
is there any way of just using the virtual address and not having to user three but just one ?
thanks
Re: HSRP and ip addresses
HI
I think u cannot do this.Becoz how ur going to use the virtual address there is no actual address.
Mahmood
yes you need to have three ip address for HSRP...virtual IP you will use as default gateway configuration in your client...
regards
Devang
Blue
there is no way to use HSRP without 3 IPs per HSRP group.
the Virtual IP basically equals either of the 2 physical IPs.
No.
Real IP address is required to identifiy each of the HSRP group member.
126
