HSRP and Load Balancing
I have one remote office with two T1's connected via a 4-port serial card off of one router. I have another 7206 which is connected to my network-with no circuits attached, and would like to utilize it in a load-balanced configuration.
My current config has ip-unnumbered for both serial links. I use EIGRP for routing updates between this router and my other WAN Routers.
I guess my main question is, what is the best design for multiple circuits on multiple core routers? I need to use HSRP for a virtual IP address and EIGRP for routing updates.
I would like to get use out of that second router, and I have a couple other offices that may get multiple circuits in the future.
Re: HSRP and Load Balancing
HSRP is for providing hosts/devices on a LAN segment a redundant default-gateway/first-hop router incase their default-gateway/first-hop router fails. It doesn't really have anything to do the WAN interfaces or routing protocols. HSRP can track/watch a Serial interface and adjust priorities if a interface goes down.
So, in your scenario you could put 1 T1 on each router and run EIGRP for routing, HSRP on the LAN providing the users with a Virtual IP address for their default gw. To load balance, you would use 2 HSRP groups (MHSRP) and 2 Virtual IP addresses. One group would be active on one router and the other group active on the 2nd router. You would then assign half the users to the 1st Virtual IP and the other half to the 2nd Virtual IP.
ebergquist is correct . . . the config could look like:
ROUTER A ---------------------------------
interface FastEthernet0/0
ip address 192.168.231.251 255.255.255.0
standby 1 priority 95 preempt
standby 1 ip 192.168.231.254
standby 1 track Se0/0
standby 2 preempt
standby 2 ip 192.168.231.253
standby 2 track Se0/0
ROUTER B ---------------------------------
ip address 192.168.231.250 255.255.255.0
standby 1 preempt
standby 2 priority 95 preempt
Good luck
Steve
In this case, if a heart-beep line is needed between router A and router B? what if the 2 router are set in 2 different sites? other user site connect them though 2 DDN lines.
226
