Webcast-Catalyst9k
HSRP between ethernet & BRI on cisco router
I want to know if it's possible to enable HSRP between ethernet interface and BRI interface?
If it's not possible, how can i do to have a automatic switch between ethernet interface and BRI interface when ethernet interface down.
Thanks!!
Re: HSRP between ethernet & BRI on cisco router
Please supply more info. Not sure what you are trying to achieve. You do not run HSPR on a single router and dont understand why you want BRI up when the ethernet goes down.
Yes, i can't put hsrp on a single router.
I want BRI up when serial goes down i'm failed with ethernet....
I want to know if when ethernet down, BRI goes up automaticaly?
thanks
One or two routers? Interface tracking commands with HSRP will work for failing over to a backup router if an interface or subinterface goes down or down/down. Backup interface commands on one router will bring up a directly connected backup link (BRI) if a serial or other (ethernet) goes down or down/down.
189
