HSRP Config in WAN and LAN
HI ALL
I have a scenario where I have to configure HSRP in both WAN and LAN side of a router.
Kindly find the Attached Diagram.
In wan side the ISP has configured HSRP and they are using static route.
The static routes are: to reach 192.168.1.0/24 they forward to 10.10.10.4 and to reach 192.168.2.0 they forward to 10.20.20.4
Router A Config:
int Fa0/0
desc LAN
ip add    192.168.2.1 255.255.255.0
int Fa0/1
desc WAN
ip add 10.20.20.4 255.255.255.248
Ip route 0.0.0.0 0.0.0.0 10.20.20.1
Kindly Help Me to config Router B and Router C
Narayanan
00971-551091485
Follow example below:
ROUTER B
interface FastEthernet0/0
ip address 10.10.10.5 255.255.255.0
duplex auto
speed auto
standby 20 ip 10.10.10.4
standby 20 timers 5 15
standby 20 preempt
standby 20 authentication "yourpassword"
end
ROUTER C
ip address 10.10.10.6 255.255.255.0
duplex auto
speed auto
standby 20 priority 10
standby 20 preempt
end
Adjust the ip address for lan side and add routes.
Regards.
HI Daniele
Thanks for your reply this config will help in wan HSRP . what about my LAN side in router B and Router C
they also need HSRP and If the Wan or Lan link goes down is should change to Standby router.
I have user the Track commands with decrement .But the issue is when Wan goes down then Wan alone changes to standby router .Lan does not change .
Rg
Karthik
ROUTER B
description WAN
duplex auto
speed auto
standby 20 preempt
end
interface FastEthernet0/1
description LAN
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
standby 20 ip 192.168.1.1
standby 20 preempt
standby 20 authentication "yoursecondpassword"
end
ROUTER C
description WAN
duplex auto
speed auto
standby 20 preempt
end
description LAN
ip address 192.168.1.3 255.255.255.0
duplex auto
speed auto
standby 20 preempt
end
You can use IP SLA and EEM to shutdown the LAN interface when the WAN goes down and viceversa.
You can follow this example:
track 100 rtr 99 reachability
delay down 5 up 60 ### consider it "down" if down for 5 secs, consider it "up" if up for 60 secs
ip sla 99
icmp-echo 10.10.10.6 source-interface F0/1
frequency 10
ip sla schedule 99 life forever start-time now
event manager environment _interface_to_shut fa0/1
event manager applet shut_some_interface
event track 151 state down
action 1 cli command "enable"
action 2 cli command "conf t"
action 2 cli command "interface f0/1"
action 3 cli command "shut"
action 4 cli command "end"
You can find more examples in community threads.
Regards.
820
