HSRP Help
I have 2 switches connected to a Layer 3 switch router.
Switch1 is connected to Router1 via trunk port 28
Switch2 is connected to Router1 via trunk port 27
Both switches are in the same Vlan
2 Routers
192.168.1.1 and 192.168.1.2
Vlan 10 IP 192.168.1.0 255.255.255.0
Help me out with the configuration:
conf t
int g2/0/28.10
encap 1dotq 10
standby 100 ip 192.168.0.1
standby 100 priority 110
standby 100 preempt
int g2/0/27.10
encap 1dotq 10
standby 100 preempt
Where do I put the physical address (192.168.1.2)for the port?
Also what do I assign the 192.168.0.1 address to on the router, is it for Vlan 1 ?
Silver
Re: HSRP Help
On the Layer 3 switch just use VLANs instead (not to use no switchport mode).
To do HSRP you need at least two L3 devices, you can do HSRP on L3 device.
On the first L3 device:
interface vlan 10
ip address 192.168.1.2 255.255.255.0
standby 100 ip 192.168.1.1
standby 100 preempt
On the other L3 device:
interface vlan 10
ip address 192.168.1.3 255.255.255.0
standby 100 priority 100
standby 100 preempt
And assign VLAN 10 to the proper interface with
switchport access vlan 10
I hope I am correct.
Anyway not clear for me what kind of equipments you have...
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a00801e85d0.html
Bye,
FCS
Re: HSRP Help
Your saying the Standby ip is the Gateway IP for vlan 10?
Re: HSRP Help
Re: HSRP Help
Hi Noobie,
the working configurations as follow for the follows switchez.
for HSRP, u need to have minimum of 2 Nos.of Layer 3 switches,
Layer 3 Switch-1(eg.assuming 3550-12T)
interface vlan 2
description ***Switch VLAN***
standby 2 ip 192.168.1.1
standby 2 timers 5 15
standby 2 priority 110
standby 2 preempt
interface gi 0/1
description ***switch-A***
switchport mode trunk
interface gi 0/2
description ***switch-B***
interface gi 0/3
description ***Layer3-switch-B***
switchport mode trunk encapsulation dot1q
Layer 3 Switch-2
interface vlan 2
standby 2 priority 109
standby 2 preempt
interface gi 0/1
interface gi 0/2
interface gi 0/3
description ***Layer3-switch-A***
on the layer switches(assuming 2950T-24),
switch-A
interface gi 0/1
interface gi 0/2
switch-B
interface gi 0/1
interface gi 0/2
Note: what ever vlans you create in layer 3 swith A, you should also create in layer 3 switch B, on the server/client pc, the gateway should be the standby IP, which means eg.the standby ip address will act as 192.168.1.2 if 192.168.1.1 fails & vice versa.
hope this helps.
rate this post
Re: HSRP Help
sorry noobie,
in my previous response, finally i mentioned "eg.the standby ip address will act as 192.168.1.2 if 192.168.1.1 fails & vice versa. " actually it is if 192.168.1.2 fails 192.168.1.1 will act as 192.168.1.3 & vice versa.
Re: HSRP Help
Perfect!
Next question...
What if SwitchB connects to Router B via switchC that connects to Router B
RouterA ---------RouterB
' SwitchB-------SwitchC
SwitchA
Would it still be
int Gi 0/2
description ****Layer 3 Switch B ****
or is there anyother configuration needed on SwitchB?
Silver
Re: HSRP Help
In your topology, when Router A fail there will be no connectivity between the swithes and Router B. So in this case you can't enjoy the advantage of HSRP. Router A is a weak point of your infrastructure.
Connect all your L2 switches to the routers with trunk connection. You just set the uplink ports (to the routers and if you have link between the swithces also set trunk - STP will block the ports, so no loop occur) trunk mode with the comand "switchport mode trunk".
If you can please redesign your environment.
Bye
FCS
Please rate me if I helped.
Re: HSRP Help
Actually all switches are connected to the routers but in this textbox the format is messed up. This is what I actually meant.
Perfect!
Next question...
RouterA ----------RouterB
| SwitchB-------SwitchC..|
SwitchA--------------------|
Would it still be
int Gi 0/2
Silver
Re: HSRP Help
You don't need extra configuration on Switch B and C, since HSRP are on Router A and B. For Switch B, C and also for A the real GW is not significant they don't need to know which Router is active in HSRP (which is the current GW - they will use just the standby IP as GW). On the swithes set the default gateway as usually with ip default-gateway global configuration command and also set the connection between the switches and routers to trunk.
Go ahead, you can do it...
Bye
FCS
Rate me if I helped.
213
