Community Member
HSRP - Hot Standby Routing Protocol
Consider a situation in which customer 1 is connected to the same Internet Service Provider via two links. For redundancy and load sharing proposal I will use BGP. I would like to know if I can configure the routers with HSRP even I am
using BGP.
Community Member
Re: HSRP - Hot Standby Routing Protocol
BGP is enough to provide Loadsharing across the links. To provide reliable redundancy in the network we can configure HSRP.
Community Member
If the two links are provided on physically separate routers then yes, you can run HSRP between them to provide a backup service. Just make sure you get the ISP to put the appropriate secondary routes in at their end.
Example:
If you have 2 routers, each with an E1 to the same ISP, HSRP between them with the Ethenet ports tracking the Serial, this will work fine.
As an after thought:
Be aware though that if an E1 port goes down, HSRP will kick in correctly HOWEVER..if an Ethernet port goes down it's a different story. The standby router will not know that the active routers Ethernet port is down and will stay in standby. To get over this a colleague is looking at running IBGP using the private BGP AS range. Can't give you an ETA though as he's busy - sorry.
Ali
1570
