hsrp issue...
hi,
i have 2 4506 switches, running as Primary and Secondary core. I have a hsrp configured for different interfaces... On primary switch,
Interface Grp Prio P State Active addr Standby addr Group addr
Vl91 0 200 P Standby 10.3.109.249 local 10.3.18.1
where, 10.3.109.249 is also the interface IP of the same primary switch. I have same hsrp group number configured for all interfaces.. Please help me understand the problem and solution.
Blue
Re: hsrp issue...
Moshin:
We cant give you a solution unless you tell us what the problem is.
Why dont you copy and paste from the routers' configs so we can see exactly whats going on?
Re: hsrp issue...
What is problem?
Re: hsrp issue...
Primary
Vl4 0 200 P Active local 10.3.11.250 10.3.11.1
Vl5 0 200 P Active local 10.3.12.250 10.3.12.1
Vl6 0 200 P Active local 10.3.13.250 10.3.13.1
Secondary
Vl4 0 100 Standby 10.3.11.249 local 10.3.11.1
Vl5 0 100 Standby 10.3.12.249 local 10.3.12.1
Vl6 0 100 Standby 10.3.13.249 local 10.3.13.1
Vl91 0 100 Init unknown unknown 10.3.18.1
Configuration:
Primary
interface Vlan4
ip address 10.3.11.249 255.255.255.0
no ip redirects
standby ip 10.3.11.1
standby priority 200
standby preempt
interface Vlan5
ip address 10.3.12.249 255.255.255.0
no ip redirects
standby ip 10.3.12.1
standby preempt
interface Vlan6
ip address 10.3.13.249 255.255.255.0
no ip redirects
standby ip 10.3.13.1
standby preempt
interface Vlan91
ip address 10.3.18.249 255.255.255.0
no ip redirects
standby ip 10.3.18.1
standby preempt
Secondary
interface Vlan4
ip address 10.3.11.250 255.255.255.0
no ip redirects
interface Vlan5
ip address 10.3.12.250 255.255.255.0
no ip redirects
interface Vlan6
ip address 10.3.13.250 255.255.255.0
no ip redirects
interface Vlan91
ip address 10.3.18.250 255.255.255.0
no ip redirects
If you look at vlan 91, you can see there is no difference in the configuration with the other vlan configs. BUT
1. I am getting syslog msgs (mnemonic=DIFFVIP1)Desc=Vlan91 Group 0 active routers virtual almost 1000 times a day..
2. Due to the fact that vlan91 is not functional, ports on secondary core which are in vlan 91 do not respond. There was a machine (for vlan 91) which was showing ping responce in a odd fasihion . like this.
1. reply from destination
2. Time out
3. reply from destination
4. time out
5. reply from destination
6. time out (and so on).
As soon as we SHUT down the Vlan91 on secondary switch, the ping response got smooth.. That means, vlan 91 (due to its init state in secondary switch) is problematic.
M question is, what is wrong in the configuration? if there is nothing wrong, then what else could be the problem?
Re: hsrp issue...
Moshin,
It looks like vlan91 interface on both switches can't communicate with each other eg. there is no L2 link.
Do you have a trunk between the primary and secondary switch? Ifso check if vlan 91 is added on both sided of the trunk.
Sander
202
