Hi All, I am trying to run HSRP in our LAN (switched Network),basically what I want to do is run HSRP.
1) My core would be composed of 3550 and 3508 switches and enable load sharing between the two.
* HSRP Group 1 active for the other segment
* HSRP Group 2 active for the other segment
This is to enable load sharing between the two and have one sement utilize the 3550 and the other utilize the 3508.
I'm not sure but I think I need Layer3 routing to be able to do this
2) The switches are connected physically thru 2 gigabit interfaces - Should I track this 2 interfaces or just track 1 interface.
I'm having confusions and not sure how to really implement this.I hope you guys can help me with this. Any input is much appreciated. Thanks,Alvin
