Webcast-Catalyst9k
HSRP on Catalyst Switches
Hi,Please someone tell me whether HSRP Can be configured on Cisco catalyst 3500 Series switches. Also plz tell me whether I can do HSRP load balancing on these products.
Sarath
Re: HSRP on Catalyst Switches
3550? Yes. 3500XL No.
GLBP? No. Multi-group HSRP? Yes.
-A
ahoejmark.....question for you? Where can I find more information on the catalyst 3550 w/emi code. I just bought one and would like to find more information on them. So you're not quite for sure if GLBP is supported on the 3550 w/emi?
Bronze
Documentation for the 3550 series is here: http://www.cisco.com/en/US/products/hw/switches/ps646/prod_technical_documentation.html
GLBP is still very new so it may be awhile before it makes its way into layer-3 switches. Perhaps someone from Cisco can comment further.
260
