hsrp problem....hsrp address not responding
I'm hoping I can get some opinions on this. I have 2 7200 routers with 2 gig interfaces each. Each gig interface is connected to 2 stacked 3750 switches. I have sub interfaces configured on both the gig interfaces so they are essentially dot1q to the 3750 switches. I have specified a hsrp group for each subinterface on the 7200s. My problem is that when I have 1 of the 7200 routers acting as hsrp active for some groups and the other 7200 acting as hsrp active for other groups hosts lose connectivity to their hsrp address for one of the routers. i.e no response to pings yet correct mac address in arp table.All works well when I make either one of the routers the hsrp active for all of the groups. Any ideas?
r1----3750----hosts
\/ | <--stack
r2----3750----hosts
Re: hsrp problem....hsrp address not responding
diagram above did not come out correctly
Hall of Fame Super Bronze
Let's see the 'show config' along with the 'show standby' output, please
config for one router is below.The other router is the same apart from the track command and the priority is 155. The 2 3750s have the vlans configured and dot1q trunks to both of the routers 2 gig ports.
the show standby at the moment shows the correct info ie the correct router is active for all the groups...
thanks
interface GigabitEthernet0/1
description *** Primary link to Switch 1 ***
no ip address
no ip proxy-arp
duplex auto
speed auto
media-type sfp
negotiation auto
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address x.x.x.x 255.255.255.224
no ip proxy-arp
no snmp trap link-status
standby 10 ip x.x.x.x
standby 10 priority 160
standby 10 preempt delay minimum 60
standby 10 track GigabitEthernet1/0
interface GigabitEthernet0/1.30
encapsulation dot1Q 30
ip address x.x.x.x 255.255.255.192
no ip proxy-arp
standby 30 ip x.x.x.x
standby 30 priority 160
standby 30 preempt delay minimum 60
standby 30 track GigabitEthernet1/0
interface GigabitEthernet0/1.70
encapsulation dot1Q 70
ip address x.x.x.x 255.255.255.252
no ip proxy-arp
interface FastEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description **** secondary link to switch 2 ***
no ip address
no ip proxy-arp
duplex auto
speed auto
media-type sfp
negotiation auto
interface GigabitEthernet0/2.20
encapsulation dot1Q 20
no ip proxy-arp
ip ospf network broadcast
standby 20 ip x.x.x.x
standby 20 priority 160
standby 20 preempt delay minimum 60
standby 20 track GigabitEthernet1/0
interface GigabitEthernet0/2.40
description *** N2 Web Farm ***
encapsulation dot1Q 40
no ip proxy-arp
standby 40 ip x.x.x.x
standby 40 priority 160
standby 40 preempt delay minimum 60
standby 40 track GigabitEthernet1/0
interface GigabitEthernet0/2.50
encapsulation dot1Q 50
ip address x.x.x.x 255.255.255.240
no ip proxy-arp
standby 50 ip x.x.x.x
standby 50 priority 160
standby 50 preempt delay minimum 60
standby 50 track GigabitEthernet1/0
interface GigabitEthernet0/2.80
encapsulation dot1Q 80
no ip proxy-arp
Justin,
The config looks fine.Which ARP table are you checking ? The switches or the 7200 routers ?
When you ping from the workstation, what's on the workstation ARP table ?
Can either router ping the HSRP address when you have trouble pinging ?
Can the 3750 switches ?
The arp tables on both the router and the hosts look ok in that the hsrp address's mac address is showing up. The switches mac address tables look ok too.
Pinging the hrsp address from the standby router in the group gets no response either. I haven't tried pinging from the switches but I assume if the routers can't and the hosts can't then the switches can't...but that's an assumption. btw pinging the 2 routers real addresses is fine from the hosts and from each router.
thanks
Justin,
Looking at the config one more time, I noticed
Where is the interface G1/0 on this router config ?
I didn't paste it as it isn't really relevant. It's a WAN interface to the internet I am tracking.It looks like this could be a difficult issue to find an answer to.
Very hard without posting revelant information such as IP addresses. I find it hard to understand your configuration when I'm only getting the subnet mask with xxx.xxx.xxx.xxx as the IP address.
Sorry.
no problem..the ip addresses are public IPs so I cant divulge them. I'm pretty confident that the config is fine as Ive done this a load of times before I'm just wondering if anyone has seen this issue before and what was the fix. thanks anyway
As you are able to ping the physical address and can't ping the HSRP address can you make sure the HSRP (standby) IP is on the same subnet as the physical address.
If you are using private IP address then you don't have to worry about posting the config on the forum.
Sundar
Hi Sundar
Yes all addressing correct. I've double checked that. hsrp works fine when one router is active for all groups, even the failover works.
Purple
Did you verify the users default gateway is pointed at the hsrp ip address ? It almost sounds like it is pointed to one router interface or the other and not the hsrp address.If you just have 2 interfaces up to the 7200's then to fail over hsrp you would have to kill one of the uplinks which would then leave a portion of your connections unable to get to the hsrp address they are pointed to . Also if you are tracking an interface like g0/1 then i would use a decrement value on the tracking statement on the primary side to make sure it becomes lower than the secondary side.
yep they're pointing to the hsrp address alright. we're testing the failover by pulling the g0/1 interface that is being tracked not the uplinks. the decrement value Im using is the default value of 10....active router pri is 160, standy is 155 so a decrement of 10 will mean it will drop to 150 and the standy will take over.
Justin,
It may have something to do with gratuitous ARP not working correctly. Can you configure 'standby use-bia' under the interface on both switches and see if that fixes the problem.
Sundar
Purple
Try a bigger decrement to like 20 , we had problems for some reason in the past when the decrement size was a small diffrence like you are using , use 160 and decrement by 20 .
Silver
Can you try to enable the proxy-arp and test again ?
Moreover, I suspect you may hit the bug as below. Try to follow the workaround and test again.
CSCse01124
Symptoms: The Hot Standby Router Protocol (HSRP) may not come up and may remain in the "Init" state, which can be verified in the output of the show standby brief command.
Conditions: This symptom is observed when dampening is configured on a native Gigabit Ethernet interface of a Cisco 7200 series or on a Fast Ethernet interface of a PA-FE-TX port adapter. Other types of interfaces are not affected.
Workaround: When the symptom has occurred, enter the shutdown interface configuration command followed by the no shutdown interface configuration command on the Gigabit Ethernet and Fast Ethernet interfaces of all routers of the standby group.
To prevent the symptom from occurring, remove dampening from the Gigabit Ethernet and Fast Ethernet interfaces.
http://www.cisco.com/en/US/products/ps6441/prod_release_note09186a00805e291f.html
Hope this helps.
Thanks for all the hints. I think I might try the standy use bia command with a larger decrement first and see how it goes. I suspect it's an issue with the hsrp mac address. I'll check out that bug although Im not getting any of the standby groups stuck in the Init state or I haven't configured dampening.
356
