03-29-2003 02:04 AM - edited 03-02-2019 06:15 AM
Got 2 routers configured with HSRP. 1st router (2612) is connected to leased line thru serial interface. 2nd router (1721) is connected as backup to ADSL line. 1st router is configured "standby 1 track serial 0/0:0" to track leased line outage and fire up 2nd router if necessary. What is perculiar to me is that when I disconnect the serial interface, and when i issue the command "show standby". I see that the *State has not been changed to Down* but the last line shows that the *serial0/0:0 is down*. Does anyone know why? Is it some hardware failure, IOS version problem or configuration problem?
It looks something like that.....
Etherent0/0 - Group 1
State is Active
7 states changes, last stage change 00:16:47
Parameter Interface State Decrement
Serial0/0:0 Serial0/0:0 Down 10
Thank you in advance.
Solved! Go to Solution.
03-31-2003 02:36 PM
you need the preempt keyword in the priority statement on the backup router. That allows it to take over by priority. The standalong preempt on the primary router lets it take control back after a LAN side failure. It may also need preempt in its priority statement so it can take back over after recovery from a WAN side( priority change) loss of control.
03-29-2003 05:19 AM
HRSP state could be still Active, even if Serial 0/0 goes down if your priority, after the tracking decrement by 10 is still higher than your Standby HSRP router. For example, your primary router is priority 110 standby is priority 90. You track a WAN interface, as you are doing, on your primary. It goes down and your priority is decremented to 100. You would remain active since your standby's priority (90) is lower.
Hope this helps you,
Don
03-29-2003 06:02 AM
Thanks Don. But I configured my 'actual' Active router's priority to 105 and my 'actual' Standby router's priority to 100. (sorry that I didn't mentioned that in my first posting)
The "show standby" on the 'actual' Active router looks like this.....
Ethernet0/0 - Group 1
State is Active
7 State changes, last state change 00:16:47
Preemption enabled, min delay 0 sec, sync delay 0 sec
Active router is local
Standby router is 191.8.xx.xx, priority 100 (expires in 8.309 sec)
Priority 95 (configured 105), tracking 1 object, 0 up
Name Interface Parameter Decrement State
Serial 0/0:0 Serial 0/0:0 10 Down
Thanks.
03-31-2003 02:36 PM
