Webcast-Catalyst9k
HSRP problem
Hey Folks,
I'm having an HSRP problem that's kicking my butt. I have a simple LAN with this
physical layout:
_______ _______
| DS1 |-----| DS2 |
|______| |______|
_______
| AS1 |
|______|
DS1 and DS2 are 3550's running IOS version Version 12.2(25)SEE2. The link connecting the 3550's is a fiber gig trunk link (G0/1).
The problem is that during my HSRP failover testing, when I disable g0/1 on either switch, the VLAN's (both HSRP Active and in Standby mode) go to "unknown" mode, also they get stuck in the "Init" stage.
Here is an example when the trunk link between the switches is up and active:
DS1#sh standby brief
P indicates configured to preempt.
Interface Grp Prio P State Active Standby Virtual IP
Vl200 200 110 P Active local 10.0.1.3 10.0.1.1
Vl201 200 100 P Standby 10.0.2.3 local 10.0.2.1
Vl210 200 110 P Active local 10.0.10.3 10.0.10.1
And here is after i disable the trunk link between the switches:
DS1(config)#int g0/1
DS1(config-if)#shut
DS1(config-if)#end
Vl200 200 110 P Init unknown unknown 10.0.1.1
Vl201 200 100 P Init unknown unknown 10.0.2.1
Vl210 200 110 P Init unknown unknown 10.0.10.1
I've tried everything I can think of and have come up short so far. Here are the relevant parts of
the configs, maybe you guys can see something I'm doing wrong. I appreciate any help you could provide.
DS1:
spanning-tree vlan 200,210 priority 4096
spanning-tree vlan 201 priority 8192
interface GigabitEthernet0/1
description <== To DS2 ==>
switchport trunk allowed vlan 200-250
switchport mode trunk
spanning-tree link-type point-to-point
interface Vlan200
description <== USER VLAN 200 ==>
ip address 10.0.1.2 255.255.255.0
ip helper-address 10.0.0.9
no ip redirects
no ip proxy-arp
standby 200 ip 10.0.1.1
standby 200 timers 1 3
standby 200 priority 110
standby 200 preempt
interface Vlan201
description <== USER VLAN 201 ==>
ip address 10.0.2.2 255.255.255.0
no ip redirects
no ip proxy-arp
standby 200 ip 10.0.2.1
standby 200 preempt
interface Vlan210
description <== WIRELESS VLAN 210 ==>
ip address 10.0.10.2 255.255.255.0
no ip redirects
no ip proxy-arp
standby 200 ip 10.0.10.1
standby 200 preempt
DS2:
spanning-tree vlan 200,210 priority 8192
spanning-tree vlan 201 priority 4096
description <== To DS1 ==>
interface Vlan200
ip address 10.0.1.3 255.255.255.0
no ip redirects
no ip proxy-arp
standby 200 preempt
interface Vlan201
ip address 10.0.2.3 255.255.255.0
no ip redirects
no ip proxy-arp
standby 200 preempt
interface Vlan210
ip address 10.0.10.3 255.255.255.0
no ip redirects
no ip proxy-arp
standby 200 preempt
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: HSRP problem
I recommend using different standby groups for each SVI.
Also, let's see the
show log
show vtp status
along with
show vlan
from both switches.
Re: HSRP problem
Sorry, my diagram got all messed up. Here is a text file with how it's supposed to look like.
Re: HSRP problem
Also, let's see the
show log
show vtp status
along with
show vlan
from both switches.
Re: HSRP problem
EdisonOrtiz,
I made the changes as you suggested. My SVI look like this now:
DS1:
interface Vlan200
no ip redirects
no ip proxy-arp
standby 200 preempt
interface Vlan201
no ip redirects
no ip proxy-arp
standby 201 ip 10.0.2.1
standby 201 timers 1 3
standby 201 preempt
interface Vlan210
no ip redirects
no ip proxy-arp
standby 210 ip 10.0.10.1
standby 210 timers 1 3
standby 210 priority 110
standby 210 preempt
DS2:
DS2
interface Vlan200
no ip redirects
no ip proxy-arp
standby 200 preempt
interface Vlan201
no ip redirects
no ip proxy-arp
standby 201 priority 110
standby 201 preempt
interface Vlan210
no ip redirects
no ip proxy-arp
standby 210 preempt
I'll let the output speak for itself:
DS1(config-if)#no shut
DS1(config-if)#shut
DS1(config-if)#
00:05:47: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
00:05:48: HSRP: Vl200 Grp 200 Standby router is unknown, was 10.0.1.3
00:05:48: HSRP: Vl201 Grp 201 Standby: c/Active timer expired (10.0.2.3)
00:05:48: HSRP: Vl201 Grp 201 Active router is local, was 10.0.2.3
00:05:48: HSRP: Vl201 Grp 201 Standby router is unknown, was local
00:05:48: HSRP: Vl201 Grp 201 Standby -> Active
00:05:48: %HSRP-6-STATECHANGE: Vlan201 Grp 201 state Standby -> Active
00:05:48: HSRP: Vl201 Grp 201 Redundancy "hsrp-Vl201-201" state Standby -> Active
00:05:48: HSRP: Vl210 Grp 210 Standby router is unknown, was 10.0.10.3
00:05:48: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
00:05:51: HSRP: Vl201 Grp 201 Redundancy group hsrp-Vl201-201 state Active -> Active
00:05:54: HSRP: Vl201 Grp 201 Redundancy group hsrp-Vl201-201 state Active -> Active
DS1(config-if)#end
DS1#
00:06:08: %SYS-5-CONFIG_I: Configured from console by console
DS1#sh stand
Vl200 200 110 P Active local unknown 10.0.1.1
Vl201 201 100 P Active local unknown 10.0.2.1
Vl210 210 110 P Active local unknown 10.0.10.1
DS1#
As you can see, the vlans are no longer stuck in INIT and failed over correctly. Thanks so much for the suggestion, everything looks great now.
SM
Re: HSRP problem
Glad to hear my suggestion solved your problem. Creating the same standby group on different SVIs can cause conflict at the MAC address level since the group number defines the virtual MAC.
Re: HSRP problem
I have gone through this issue. what i feel Even though if you use same standby group on different SVIs , Same Virtual MAC address will be for all. but Cisco switches support Vlan based MAC table which should not create any issue of conflict of same virtual Mac address.
Please refer this link.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_qanda_item09186a00801cb707.shtml#q8
Can you please clarify more on your suggestion ?
Re: HSRP problem
I agree with your assessment, it should maintain a per-VLAN MAC address table. I've used both combinations (same group on multiple interfaces as well as different group per interface) and they've worked. However, I feel the configuration is more robust when you define a different group per interface.
From the link you posted, Cisco leaves an opening for error when they state 'in most modern switches'.
239
