HSRP problems with OSPF
hello all,
I have an architecture problem. Here is my network
architecture:
/---------------Router B---------------\
Router A LAN
\---------------Router C---------------/
On the LAN side, HSRP is configured (Router C is
active). OSPF is used as routing protocol on each
router.
If Router C fails, HSRP works well and packets pass
through router B after 10 seconds. But when Router C
comes up again, HSRP immediately (in 10 seconds)
redirects packets on Router C but OSPF routing table of Router C isn't effective before 1 minute so during 1 minute every packets are dropped. What can I do to avoid this problem?
Thanks for your help.
1 REPLY
Re: HSRP problems with OSPF
You can use the "standby preempt delay 60" directive to keep HSRP from immediately failing back to the primary router.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipras_r/1rfip2.htm#xtocid34
Mick.
106
