HSRP Problems
I have two Cisco 4503 switches with Sup IIIs running 12.1(20) enhanced. They are dual connected to each other. A show standby shows the correct information i.e. that one is active and one is standby. However when I power off the active router the standby does not assume the virtual address and does not make itself active. Anyone had similar problems?
Re: HSRP Problems
Not really, but you did provide not too much info.
Could we have some configs?
What is the output of "sh stand" before and after the primary system is switched off?
In the output of sh stand, there is a line that states when the last hsrp-packet was seen and I am curious what it says.
Leo
Re: HSRP Problems
I have attached the 2 configs. Also below is the output of a show standby on the 2 switches. Difficult for me to obtain the output when one is powered off as they are in a live environment.
Sh standby on switch1
MACRCORE01#sh standby
Vlan1 - Group 1
Local state is Active, priority 150, may preempt
Hellotime 3 sec, holdtime 10 sec
Next hello sent in 2.206
Virtual IP address is 180.90.1.1 configured
Active router is local
Standby router is 180.90.1.254 expires in 7.088
Virtual mac address is 0000.0c07.ac01
2 state changes, last state change 17:12:30
IP redundancy name is "hsrp-Vl1-1" (default)
Sh standby on Switch 2
MACRCORE02#sh standby
Vlan1 - Group 1
Local state is Standby, priority 110
Next hello sent in 2.462
Active router is 180.90.1.253, priority 150 expires in 8.892
Standby router is local
15 state changes, last state change 17:09:22
Re: HSRP Problems
It is a pity that you could not upload the output of: sh stand when it is not working.
I meant these two lines:
Active router is 180.90.1.253, priority 150 expires in 8.892 << THIS TIMEOUT SHOULD BE CHECKED
The active router should expire after about 10s.
Your hsrp-config looks OK.
One more thing to try is to put all links in the port-channel on the same board. Now you have 1/1 and 3/1 as members. Besides, the following URL might be of help:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml#top9
Leo
Re: HSRP Problems
Try adding these lines to each router under VLAN1:
standby 1 timers 5 10
standby 1 preempt
This will probably make things fail over more smoothly..
122
