HSRP using VLAN with different network subnet masks
I have configured a few VLANs uplinked to 2 x 4506 L2/L3 devices. All VLANs,
except one, is a different 10.1.n.n/24 network and the 4506's are configured for HSRP for each VLAN. ( .1 virtual, .2, .3). As well, OSFP has the 10.1.0.0 network defined.
HSRP tests between the VLANs using SHUTDOWN worked well.
Then I added a 159.128.208.0/21 VLAN to the configuration. HSRP was defined on the 2x4506 switches as for teh other VLANs. The VLAN was not added to OSPF.
Connectivity to/from these two network groups was confirmed.
However, HSRP tests were strange. If the ping is sent from 159.128.208.0 to a device on any 10.1.0.0 VLAN and the active 10.1.0.0 or 159.128.208.0 router interface is shutdown, recovery either does not happen at all, or every second ping times out.
Is there a problem with OSPG and HSRP together?
Should I add this new network to OSPF?
Bronze
Re: HSRP using VLAN with different network subnet masks
At the first look, it looks really strange but What i can visualize is that your ping requests are reaching your destination but the replies somehow come in two direction (May be the routing table has 2 paths for the return path) and one of the reply dont reach ping originator because one of the HSRP interface is shutdown.
I would better check the routing table for any multiple paths in both directions
Bronze
Indeed without more info on the topology I would guess that (some of) the return traffic ends up on the switch where the vlan interface is shutdown and this switch does not have a route to 159.128.208.0.
Possible solutions:
- add 159.128.208.0 to ospf (and use passive-interface if you do not want to route over this vlan)
- redistribute connected in ospf
- add a static route to 159.128.208.0 via the other switch (it will be overridden by the connected route as long as the vlan interface is up)
hth
Herbert
183
