HSRP with secondary addresses?
llo
I have a problem configuring HSRP with secondary addresses on 2 Cisco 2811:s. On each router, fa0/0 is connected to the same switch. They see eachother with cdp.
On the LAN, there are clients with IP:s in both 172.17.2.0/24 and 172.17.3.0/24. The final goal is to use 172.17.x.2 as default gateway on all hosts. Router lugw01 is to be the active router on all interfaces while lugw02 is just a "hot spare" standing by.
The problem is that I cant get HSRP working with secondary:s. What am I doing wrong? According to CCO I think I have configured it the right way.
This is the interresting parts of the configurations:
hostname lugw01
interface FastEthernet0/0
description Internal LAN
ip address 172.17.3.3 255.255.255.0 secondary
ip address 172.17.2.3 255.255.255.0
duplex auto
speed auto
standby 2 ip 172.17.2.2
standby 2 priority 200
standby 2 preempt
standby 3 ip 172.17.3.2 secondary
standby 3 priority 200
standby 3 preempt
hostname lugw02
ip address 172.17.3.4 255.255.255.0 secondary
ip address 172.17.2.4 255.255.255.0
duplex auto
speed auto
standby 2 preempt
standby 3 preempt
As You can see below, standby group 3 is never going to Active state.
lugw01#sh stand
FastEthernet0/0 - Group 2
State is Active
4 state changes, last state change 00:03:07
Virtual IP address is 172.17.2.2
Active virtual MAC address is 0000.0c07.ac02
Local virtual MAC address is 0000.0c07.ac02 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 1.216 secs
Preemption enabled
Active router is local
Standby router is 172.17.2.4, priority 100 (expires in 9.212 sec)
Priority 200 (configured 200)
IP redundancy name is "hsrp-Fa0/0-2" (default)
FastEthernet0/0 - Group 3
State is Learn
Virtual IP address is unknown
Secondary virtual IP address 172.17.3.2
Active virtual MAC address is unknown
Local virtual MAC address is 0000.0c07.ac03 (v1 default)
Preemption enabled
Active router is unknown
Standby router is unknown
IP redundancy name is "hsrp-Fa0/0-3" (default)
lugw02#sh stand
State is Standby
4 state changes, last state change 00:03:20
Next hello sent in 0.236 secs
Preemption enabled
Active router is 172.17.2.3, priority 200 (expires in 9.236 sec)
Standby router is local
Priority 100 (default 100)
State is Learn
Preemption enabled
Re: HSRP with secondary addresses?
Output from "deb standby" when I do "no shut" on int fa0/0:
*Sep 13 11:49:50.027: HSRP: Fa0/0 API 172.17.2.3 is not an HSRP address
*Sep 13 11:49:50.027: HSRP: Fa0/0 API 172.17.3.3 is not an HSRP address
*Sep 13 11:49:50.027: HSRP: Fa0/0 API MAC address update
*Sep 13 11:49:50.035: HSRP: Fa0/0 API Software interface coming up
*Sep 13 11:49:50.039: HSRP: Fa0/0 API Add active HSRP addresses to ARP table
*Sep 13 11:49:52.027: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Sep 13 11:49:52.027: HSRP: API Hardware state change
*Sep 13 11:49:52.027: HSRP: Fa0/0 API Software interface coming up
*Sep 13 11:49:52.027: HSRP: Fa0/0 Grp 2 Hello in 172.17.2.4 Active pri 100 vIP 172.17.2.2
*Sep 13 11:49:52.027: HSRP: Fa0/0 Grp 2 Active router is 172.17.2.4
*Sep 13 11:49:53.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Sep 13 11:49:55.027: HSRP: Fa0/0 Grp 2 Hello in 172.17.2.4 Active pri 100 vIP 172.17.2.2
*Sep 13 11:49:57.927: HSRP: Fa0/0 Redirect adv out, Dormant, active 0 passive 0
*Sep 13 11:49:58.027: HSRP: Fa0/0 Grp 2 Hello in 172.17.2.4 Active pri 100 vIP 172.17.2.2
*Sep 13 11:49:59.743: HSRP: Fa0/0 Interface up
*Sep 13 11:49:59.743: HSRP: Fa0/0 Starting minimum interface delay (1 secs)
*Sep 13 11:50:00.743: HSRP: Fa0/0 Interface min delay expired
*Sep 13 11:50:00.743: HSRP: Fa0/0 Grp 2 Init: a/HSRP enabled
*Sep 13 11:50:00.743: HSRP: Fa0/0 Grp 2 Init -> Listen
*Sep 13 11:50:00.743: HSRP: Fa0/0 Grp 2 Redundancy "hsrp-Fa0/0-2" state Init -> Backup
*Sep 13 11:50:00.743: HSRP: Fa0/0 Redirect adv out, Passive, active 0 passive 1
*Sep 13 11:50:00.743: HSRP: Fa0/0 Grp 3 Init: a/HSRP enabled
*Sep 13 11:50:00.743: HSRP: Fa0/0 Grp 3 Init -> Learn
*Sep 13 11:50:00.743: HSRP: Fa0/0 Grp 3 Redundancy "hsrp-Fa0/0-3" state Init -> Learn
*Sep 13 11:50:01.027: HSRP: Fa0/0 Grp 2 Hello in 172.17.2.4 Active pri 100 vIP 172.17.2.2
*Sep 13 11:50:01.027: HSRP: Fa0/0 Grp 2 Listen: h/Hello rcvd from lower pri Active router (100/172.17.2.4)
*Sep 13 11:50:01.027: HSRP: Fa0/0 Grp 2 Active router is local, was 172.17.2.4
*Sep 13 11:50:01.027: HSRP: Fa0/0 Redirect adv out, Active, active 1 passive 3
*Sep 13 11:50:01.027: HSRP: Fa0/0 Grp 2 Coup out 172.17.2.3 Listen pri 200 vIP 172.17.2.2
*Sep 13 11:50:01.027: HSRP: Fa0/0 Grp 2 Listen -> Active
*Sep 13 11:50:01.027: %HSRP-6-STATECHANGE: FastEthernet0/0 Grp 2 state Listen -> Active
*Sep 13 11:50:01.027: HSRP: Fa0/0 Grp 2 Redundancy "hsrp-Fa0/0-2" state Backup -> Active
*Sep 13 11:50:01.027: HSRP: Fa0/0 Redirect adv out, Active, active 1 passive 2
Best regards
Jimmy Larsson
Silver
Can you reduce the priority on the primary router to about 105 instead of 200 and check if it works
I did, but it´s the same thing.
State is Active
9 state changes, last state change 00:00:37
Next hello sent in 1.884 secs
Preemption enabled
Standby router is 172.17.2.4, priority 100 (expires in 9.420 sec)
Priority 105 (configured 105)
State is Learn
Preemption enabled
duplex auto
speed auto
standby 2 priority 105
standby 2 preempt
standby 3 priority 105
standby 3 preempt
Any more suggestions?
Hall of Fame Super Silver
My suggestion is to change the configuration of group 3 and make it part of group 2.
standby 2 ip 172.17.3.2 secondary
As this part of the show command illustrates there is the ability to have a virtual address and a secondary virtual address in the same group.
State is Learn
Rick
285
