Webcast-Catalyst9k
HSRP with Secondary Interface Addresses
Hi All,
I am adding a second router for redundancy. When configuring HSRP for an interface with primary and secondary ip addresses do I need to configure a seperate HSRP group for each. For example:
r1
int e0
ip address 10.0.0.2 255.255.255.0
ip address 192.168.1.2 255.255.255.0 secondary
standby 10 ip 10.0.0.1
standby 10 priority 110
standby 10 preempt
standby 192 ip 192.168.1.1
standby 192 priority 110
standby 192 preempt
r2
int e0
ip address 10.0.0.3 255.255.255.0
ip address 192.168.1.3 255.255.255.0 secondary
standby 10 priority 100
standby 10 preempt
standby 192 priority 100
standby 192 preempt
or do I use
standby 10 ip 192.168.1.1 secondary
instead.
Thanks in advance.
Joe
Bronze
Re: HSRP with Secondary Interface Addresses
The way you have configured it, with multiple standby groups, is correct. See the following URL for an example -
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/cs009.htm
No, you don't need to use another standby group for the secondary HSRP address. You could also do it like:
standby ip 10.0.01
standby ip 192.168.1.1 secondary
-A
116
