Community Member
I am building a home lab. I have a 1841 router connected to the ISP router and is configured and works good. I have 3550 switch
I am building a home lab. I have a 1841 router connected to the ISP router and is configured and works good. I have 3550 switch inside my network. I can ping as far as the outside interface on the router, but not further then that. No idea why. I have enabled IP routing on the switch and I have redirected all unknown traffic out of the routers interface. Can anyone suggest something. I have no idea why is not working.
1 ACCEPTED SOLUTION
Hi , Check your NATing ,
Hi ,
 Check your NATing , configured on your router . When you say you cant ping further , suspecting checks to be done on NAT/PAT
Sandy
Hall of Fame Super Gold
Disable "ip routing" of your
Disable "ip routing" of your switch.
Instead, configure router-on-a-stick.  Your router should be doing the routing.  Enable Dot1Q trunking between router and switch interface.
Community Member
Hi Leo Thank you for the
Hi Leo
Thank you for the answer.
I tried what you said. I disable the IP routing on the switch and I configure the interface fa0/1 on the router with sub-interface and I used the encapsulation dot1q. On the switch I configured the interface that I have the PC as access and the interface that goes to the router as a trunking. But still the same problem.
Still no idea why. Normally this should work without any problem...
Hi ,
Sandy
Community Member
Sorry I pressed the correct
Sorry I pressed the correct answer by mistake. I wish that was the answer.
I can ping the internet and any ip address or domain name from the router. But not from the pc connected to the switch
Hi ,   Kindly share me your
Hi ,
   Kindly share me your router & switch config
1) when you say you are able to ping all destination from router , not from PC and switch following things to be checked
a) NAT/PAT
b) LAN network extend-ability over to switch .
Sandy
421
