Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
I can not connect trunking Catalyst 4006 and AT8324SX Allied Telesyn
Hi all,
I can not connect trunking between Catalyst 4006 and AT8324SX Allied Telesyn by 802.1q. Pls help me solve this problem, below is my configuration:
interface FastEthernet2/34
switchport mode trunk
duplex full
no snmp trap link-status
and below is sh command:
APV4006#sh int trunk
Port Mode Encapsulation Status Native vlan
Fa2/34 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa2/34 1-1005
Port Vlans allowed and active in management domain
Fa2/34 1-4,7,1002-1005
Port Vlans in spanning tree forwarding state and not pruned
FAPV4006#sh int fa2/34 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
FAPV4006#sh vlan
VLAN Name Status Ports
1 default active Gi1/1, Gi1/2, Fa2/33
2 VLAN2 active Fa2/29, Fa2/30, Fa2/31, Fa2/35
3 VLAN3 active Fa2/1, Fa2/2, Fa2/3, Fa2/4
Fa2/5, Fa2/6, Fa2/7, Fa2/8
Fa2/9, Fa2/10, Fa2/11, Fa2/12
Fa2/13, Fa2/14, Fa2/15, Fa2/16
Fa2/17, Fa2/18, Fa2/19, Fa2/20
Fa2/21, Fa2/22, Fa2/23
4 VLAN4 active Fa2/24, Fa2/25, Fa2/26, Fa2/27
Fa2/28, Fa2/36
7 VLAN7 active Fa2/32
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
2 enet 100002 1500 - - - - - 0 0
3 enet 100003 1500 - - - - - 0 0
4 enet 100004 1500 - - - - - 0 0
7 enet 100007 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Primary Secondary Type Ports
Thank you very much
Hung
Re: I can not connect trunking Catalyst 4006 and AT8324SX Allied
I don't know Allied Telesyn configuration.
But generally while 802.1q trunking to other vendor switch there might be two basic problems:
1) Negotiation of Trunking: On in your Cisco config - the other side might not support trunk negotiation, try to change to "no negotiation"
2) native VLAN1 - the other side might not support native VLAN (untagged frames) feature on 802.1q trunk. There is "dot1q-all-tagged" possibility in CatOS and there should be something similar in IOS (I don't remember the exact command).
Milan
If memory serves, the AT switches tag all vlans, point 2 is correct.
Another way to get the trunking working is to set the native vlan on the Catalyst to some unused number. You don't say whether the 4006 has a Supervisor II or III in it, so it might be running CatOS or IOS. If the unused vlan is 999...
- on SupII
set vlan 999 x/y
- on SupIII
int x/y.999
encapsulation dot1q 999 native
557
