09-07-2006 11:52 PM - edited 03-03-2019 04:52 AM
PC-A IP=10.1.1.1 +-hub-+[e0/0:10.1.1.5 RouterA s0/0:195.1.1.4]===V35===[s0:195.1.1.10 RouterB 152.1.1.1:e0]+-hub--+[e0:RouterC 152.1.1.2]
Router configuration is attached.
If I remove the entries
int e0/0
ip nat inside
and
int s0/0
ip nat outside
from RouterA, I can ping from PC-A (10.1.1.1) to 152.1.1.2 just fine. If add the respective nat entries on e0/0 and s0/0, ping from PC-A (10.1.1.1) to RouterC (152.1.1.2) times out.
What am I missing ? I am trying to apply NAT in order to get the address 10.1.1.1 translated into 195.1.1.1.
I guess somehow the NAT statements are causing a conflict in the ip route statements, but I can't figure out why.
09-08-2006 12:04 AM
Have you tried use the NAT with overload option?
It can be like this:
ip nat inside source list "ACL" interface "interface" overload
ACL - restrict allowed IP range for NAT
bye
FCS
Pleasa rate me if I helped.
09-08-2006 12:14 AM
The routes you are giving are wrong.the should have been default routes instead of network specific routes....for eg
Instead of 10.1.1.0 255.255.255.0 195.1.1.4, it should have been 0.0.0.0 0.0.0.0 s0 etc.
Then i believe your NAT statements would work.
Router A
interface Ethernet0/0
ip address 10.1.1.5 255.255.255.0
ip nat inside
interface Serial0/0
ip address 195.1.1.4 255.255.255.0
ip nat outside
ip nat inside source static 10.1.1.1 195.1.1.1
ip nat inside source list 1 interface s0/0 overload
ip route 0.0.0.0 0.0.0.0 195.1.1.10
access-list 1 permit ip 10.1.1.0 0.0.0.255
Router B
ip address 152.1.1.1 255.255.255.0
interface Serial0/0
ip address 195.1.1.10 255.255.255.0
ip route 0.0.0.0 0.0.0.0 195.1.1.4
Now from ip pool 152.1.1.0, if you will ping 195.1.1.1, you will get.But if you will ping 10.x.x.x you wont be able to...simply b'coz its NAT.
Hope that will help, revert back if u have more queries.
Pls rate helpful posts.
JD
09-08-2006 08:19 PM
Another question:
If I use dynamic tables instead (i.e., router RIP) of using the default route, everything seems to work fine.
My question is, in production environments usually you would be dealing the ip nat statements without dealing with default routes ? Or I guess that varies and in many production environments you end up with static/default routes as well ?
09-08-2006 09:52 PM
U mean to say that you are able to ping the IPs behind NAT?
JD
09-08-2006 11:19 AM
Marlon,
Can I see the
show ip nat translations
from router A ?
Can you ping 195.1.1.1 from RouterA or RouterB ?
09-08-2006 04:10 PM
Hi, yes I can ping 195.1.1.1 OK from RouterA and from RouterB.
RouterA#show ip nat translations
Pro Inside global Inside local Outside local Outside global
--- 195.1.1.1 10.1.1.1 --- ---
RouterA#ping 195.1.1.1
Sending 5, 100-byte ICMP Echos to 195.1.1.1, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/2/4 ms
09-08-2006 09:39 PM
On RouterA, please remove this statement
ip route 10.1.1.0 255.255.255.0 Ethernet0/0
You don't need it because RouterA has
Which represents that network already. It will show up in the routing table as a 'connected' network.
In routerB, I want you to enter
ip route 195.1.1.1 255.255.255.255 serial0/0
Please let me know how it works and rate helpful posts.
09-09-2006 12:27 PM
Yes, that works ! Thanks !
