06-19-2002 06:47 PM - edited 03-01-2019 10:17 PM
the warnings are link this;
SLOT 6:Jun 14 11:56:54.996 cst: %LC-6-PSARESTOREUCODE: Activated PSA VANILLA ucode.
06-20-2002 12:48 PM
Message Meaning:
%LC-6-PSARESTOREUCODE: Activated [chars] ucode.
See this URL for explanation of this message:
Explanation A higher priority feature has been removed. The lower priority feature is now active.
Recommended Action No action is required. The lower priority feature is enabled because the higher priority feature is removed.
This could be (depending on what you are doing on the GSR or what type line cards (i.e Engine 1, etc) a defect in IOS, something with ACL (guessing here) that is causing your line card to change it's microcode bundle due to feature change????
Hope this helps,
Don
06-20-2002 05:02 PM
i have just upgrade the ios to 12.0(21)S2. and all the LC received this message.
