I have a Cisco 2621 router, and I try go to ROM Monitor mode.
After the router power on, I press Ctrl-F6-Break to generate the break sequence. Then, I disconnect the terminal and reconnect it with a 9600 baud rate. However, the output of the screen looks a non-human language.
I try to go to the ROM Monitor mode, but fail.
I am using Hyperterminal(version 595160), and Operating System: Windows 95
Please, help me to solve this issue !
Thanks for all Pro.
1 ACCEPTED SOLUTION
Re: I have a Cisco 2621 router, and I try go to ROM Monitor mode
I think the "non-human language" is because of a speed mismatch.
Please make sure that you have the Step 1 done on the url below;
http://www.cisco.com/en/US/partner/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
Use the following terminal settings:
9600 baud rate
No parity
8 data bits
1 stop bit
No flow control
For additional information on cabling and connecting a terminal to the console port or the AUX port, refer to the following documents:
Cabling Guide for Console and AUX Ports on Cisco Routers
Hope this helps,
yatin
1 REPLY
9600 baud rate
No parity
8 data bits
1 stop bit
No flow control
Hope this helps,
yatin
522
