Community Member
I have Cisco 2621 router with two fast Ethernet interfaces, how I can use both interfaces for load sharing and redundancy. for your information I have only one subnet in my lan 172.16.1.0/24?
I have one Cisco 2621 router with two fast Ethernet interfaces, how I can use both interfaces for load sharing and redundancy. for your information I have only one subnet in my lan 172.16.1.0/24?
Anonymous
N/A
Re: I have Cisco 2621 router with two fast Ethernet interfaces,
You can assign the same subnet (or
the same address, using IP unnumbered)
to both interfaces, and with CEF
(ip cef) switching or fast switching
enabled you will automatically get
load balancing and redundancy, as
long as both interfaces learn the same
routing updates.
Community Member
I have a 5509 with a RSM connected to a 3640 via a single link. Could you send me an example to show how to connect the 5509 to the 3640 using two links for load sharing? 2 FastE interfaces connected to 2 switchports?
Guy Lefebvre
Lombard Canada
137
