Webcast-Catalyst9k
I have problem with E1 pri and with ISDN lines
I have an E1 pri in the Central site and ISDN lines at the remote sites, the problem that I got at this time is that when the E1 site makes a call to the remote site, doesn't do it, but when the remote sites call to the E1 Central site there is no problem at all, works great. at this time I have installed 12 remote sites working in PPP with no problem at all when they make the call, but remember that when the Central site makes the call, it doesn't work at all.
Following it's a part of the configuration of the Central site E1 site and the IOS version in the 3640, E1 site.
conf
controller E1 1/1
framing NO-CRC4
pri-group timeslots 1-31
description Enlace conmutado
interface Serial1/1:15
description Enlace conmutado 4409092
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
ppp multilink
interface Dialer1
description Enlace con Pavas
ip address 30.0.0.1 255.255.255.252
encapsulation ppp
dialer in-band
dialer pool 1
dialer map ip 30.0.0.2 name pavas broadcast 2969019
dialer load-threshold 100 outbound
dialer-group 1
no fair-queue
ppp multilink
interface Dialer2
description Enlace con Cartago
ip address 30.0.0.5 255.255.255.252
encapsulation ppp
dialer in-band
dialer pool 1
dialer map ip 30.0.0.6 name cartago broadcast 5733003
dialer-group 1
no fair-queue
ppp multilink
multilink max-links 2
version is flash:c3640-is-mz.121-5.T
Re: I have problem with E1 pri and with ISDN lines
Often times complex troubleshooting issues are best addressed in an interactive trouble-shooting session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit http://www.cisco.com/tac and to open a case with one of our TAC engineers, visit http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Ensure whether the E1 PRI leased from Teleco is configured for both incoming and outgoing
traffic in the teleco switch.By default, your ISDN BRI are configured for both incoming& outgoing
calls in the teleco switch.
regds,
d.k
what says your dialer-list 1? you should have one to spec intersting traffic.
I remember such a pb the reason was the pri line had only 16 IT so the call tried to get out
on a IT that didn't exist.the incoming calls were ok because they arrived on low IT.
try the deb isdn q931 to see the reasons why it don't work.
134
