Webcast-Catalyst9k
I have two devices pumping out X21 using a leased line in between. Can I replace the leased line with an ISDN PRI somehow doing some sort of X21 to ISDN PRI conversion. Is there an example of this anywhere ?
I have two devices pumping out X21 using a leased line inbetween. Can I replace the leased line with an ISDN PRI somehow doing some sort of X21 to ISDN PRI conversion. Is there an example of this anywhere ?
I want the ISDN PRI to be DDR.
Has anyone done something similar with
example configs if this is possible ?
1 REPLY
Anonymous
N/A
Re: I have two devices pumping out X21 using a leased line in be
The best that you could do is to get an
ISDN TA (this is BRI, not PRI) with an
X.21 interface. The serial interface
would then be configured for DDR.
85
