Community Member
I NEED HELP, any sugest would be really apreciated
I have a small lan in my house and I have 2 broad band internet conections with a cisco 677 modem, each cisco modem y attached to a 4 port hub, but now i want to change the 2 hubs for a 16 ports switch, so my question is
COULD I CONECT THE 2 MODEMS IN A SWITCH WITHOUT TROUBLE, AND IF THERE ANY TROUBLE COULD YOU HELP ME OUT?
Re: I NEED HELP, any sugest would be really apreciated
as far as communication is concerned, the switch should transparently replace the hub, you have....
Community Member
Just make sure that you'll get a managable switch. That is something that you can console or telnet to the switch to create VLANs. By the sound of things, I recommend that you'll make 2 VLANs to connect your modems to.
135
