Webcast-Catalyst9k
I need help on routing issue. Urgent!!!
I have a 2503 (Ethernet 0 @ 202.126.180.145) and is connected to a firewall @ 202.126.180.155 directly using a Cross cable. I have NAT setup in the firewall to translate IP addresses 202.126.180.146-153 to 192.1.1.1-192.1.1.8
I could ping the firewall and the PC behind the firewall (ie. 192.1.1.1-192.1.1.8), however, i am not able to ping using 202.126.180.146-153. I have tried using another LINUX router to replace the CISCO 2503 and it works.
I gather the problem should lies on the routing for network 202.126.180.144
hence, i configure
ip route 202.126.180.144 255.255.255.240 202.126.180.155,
but, still not working.
Please help me on the above. Thanks.
1 REPLY
Gold
Re: I need help on routing issue. Urgent!!!
You should only be able to ping one set of addresses through the PIX--the translated address. You won't be able to (or shouldn't be able to ) ping the PC's real addresses, even if you have routes to them.
Russ
68
