I need help.
I got two lan separeted by two routers Cisco 1600 and a serial cable, with hosts win 2k at both side.
All is working fine: ping, tracert and I can map every host from every host. I got no server D.N.S, only workstastions with files lmhosts compiled.
The problem is: why in network neighborhood the workgroup of the opposite lan do not appeare automatically?
Must I use necessarily D.N.S. servers?
In the configurations files of the routers I have activated: ip directed-broadcast.
Thanks.
Silver
Re: I need help.
It's been awhile for the Microsoft stuff but here goes...
For browsers to exchange information between layer 3 networks you need a WINS server that all hosts register with. I believe this would allow you to see all your hosts in network neighborhood. On local layer 2 segments the browse master will allow all your hosts within a workgroup/domain to see each other. This (WINS) is pretty easy to setup if you have an NT Server somewhere in your network.
Hope this helps,
Don
Re: I need help.
Thank you Don for your help,
Giovanni
Bronze
Re: I need help.
this is very good URL for your ref.
http://www.cisco.com/warp/customer/473/winnt_dg.htm
Re: I need help.
thank you for the intormation but I am not able to reach the url because it doesn't accept my user name and password, and if I must make a new registration I should be CCIE which I am not.
If you are so kind to send me the page by email, I will appreciate. My mail is: gbsalerno@libero.it
72
