I need to test periodically my isdn conn on several remote routers because isdn is configurated for backing up leased lines.
I need to test periodically my isdn connection on several remote routers because isdn are configurated for backing up leased lines.
I tried with a batch script, but after the execution of the ping command the router doesn't accept the exit command and return control to the script.
1 REPLY
Anonymous
N/A
Re: I need to test periodically my isdn conn on several remote r
Make sure the script delay's entering
"exit", until the ping has completed.
By default a ping will send 5 packets
with a 2 second timeout, which means
that if every ping fails the ping
process will still take 10 seconds to
complete.
82
