I've got an 8 port BRI ISDN module on a 3640. 4 BRI ISDN interfaces are sharing the same telephone number. Is it possible to support multiple simultaneous dial-up connections with callback and how is it done? Do I need multiple dialer interfaces and pools
The telco has configured 4 S/T BRI interfaces into the same group under a single number. all of the isdn interfaces have the following config:
int bri1/0
no ip address
encap ppp
dialer pool-member 1
isdn sw basic-net3
isdn incoming-voice modem (for digital modems)
isdn send-alerting
ppp auth chap pap callin
the dialer interface
int dialer1
ip unnum eth 0/0
encap ppp
no ip split-hor
dialer pool 1
dialer idle-time 0
dialer-group 1
peer default ip address pool D...
no cdp ena
ppp callback accept
ppp auth pap chap callin
ppp multi
the first call placed is dialed back and connects okay (full ip connectivity)
the second incoming call is called back and connects (full ip connectivity) but the first call loses ip connectivity. the call is still connected, and the ip address is still in the Router. but connectivity is dead, apart from the extremely rare returned ping packet. are there any glaring omissions in this config or is it the telco's problem, their end?
  • Other Network Infrastructure Subjects
1 REPLY
Anonymous
N/A
Re: I've got an 8 port BRI ISDN module on a 3640. 4 BRI ISDN int
Since you are using dialer profiles and
you have one dialer interface, you can
only have one user dial in. I think you
should remove the pool commands, and
just use a dialer-rotary group that can be
used by multiple users. The config would
otherwise be the same.
http://www.cisco.com/warp/customer/129/15.html
116
