Community Member
I want to be able to manually place ISDN calls to different remote sites easily. Is there a tool to do this on the Cisco 800 routers rather than have to configure the router everytime?
Our compnay has 22 branches and we had a modem dialup system to each site. For this reason all the remote site IP segments have the same IP Addressing scheme.
Similar to using Dial-Up-Networking in Windows on an analog modem or 3Com's ISDN Web Dialer Interface for manual calling, I was wondering if there was a similar tool, so we can have a 2 step process: initiate the call to the remote site by typing in the ISDN number and then after connection establishment, activate the application requirment. Only a single PC will be connected through the router to be used as a management server.
Re: I want to be able to manually place ISDN calls to different
There is a command that can be used to
establish a call for the purpose of testing
connectivity, but you would not be able
to establish a PPP connection over this
call. You can try it to see if it works
for your requirements; the command is "isdn
call interface".
