I want to use an ISDN PRI for both V.110 and V.90 dial-in users.
We have a requirement for both standard Dial-in User access, and also a wireless requirement for dialing into the router via GSM.
We have a 3640 router with an ISDN PRI, and 30 Modem card. Is it possible to configure this router to accept both types of call (V.90 and V.110)via the same PRI, or do I have to have a separate PRI (or a group of BRI's) for one of the requirements.
1 REPLY
Anonymous
N/A
Re: I want to use an ISDN PRI for both V.110 and V.90 dial-in us
You can use the same PRI; there are
no additional config requirements. You
will need 12.1(5)T or later code, and
we must recieve LLC info from the switch
indicating a V.110 call.
There is more info here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t5/dtv110dm.htm#xtocid176413
134
