IBM DB2 Connect to Cisco 2950T-24 Switch has some problem
david_tu
I have some problemes with IBM DB2 connect to cisco 2950T-24 switch.
When users use the client to connect the IBM DB2 server,it's okay.
But when the user idle to long ,then user want to use the server again.
It will appear a error mesenger on the user monitor.If the client plug in D-Link 10/100 M Hub,it's okay. I have fixed both the cisco switch port and server's NIC speed,duplex. But this suitation is appear again.I have no idea to do it.
Excuse me,anybody has this question?
s.jankowski
Level 4
Level 4
Current Issues in SNA and IP Migration is mentioned in the following document:
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_white_paper09186a0080091ed8.shtml
franklin_lopez
Hi David, Try to use the port fast in the port of the switch , some application no support time delay and if the port go down when the machine have a long time idle is possible that the NIC too, Port fast skip some step of the spannind tree and the time to up is perfomance.
Franklin Lopez
