07-01-2003 02:09 PM - edited 03-02-2019 08:33 AM
Hey all,
I now have vty 0 through 14 occupied on a router, as the idle sessions are not timing out. I have specified exec-timeout 60 0, so it should be timing out after 60 minutes, but some have been idle for 4 days. I suspect that one of the vty processes is locking the running-config as I cannot enter some commands without locking the vty session, and when entering "show running-config" I get "Unable to read configuration. Try again later".
Typing "clear line vty #" does not clear the line. Also, while typing "sh proc mem" I see that the first idle vty line session 66 is taking up 5335612 Bytes of Memory.
So I am wondering if there is an undocumented way to force kill a process or line session - or am I in need of reloading the router?
Thanks in advance.
-Jason
Solved! Go to Solution.
07-02-2003 06:55 AM
you may be hitting this bug
or
the second one lists 12.2(11)8T as an affected version
07-02-2003 04:13 AM
You can do a sh tcp br , then find the TCB # , then clear tcp tcb
bug # CSCdk81950
Release Notes
Incomming telnet connections do not get closed after the telnet session
is exited. The tcp connections state remains on the router and the connections
do not timeout and go away and remain until the router is rebooted.
The workaroud is to use "clear tcp
the tcb of the hung tcp connection after using "show tcp brief"
to list the tcb''s associated with the tcp connections.
07-02-2003 06:01 AM
Thanks for the tip. It did in fact clear the hung tcb connections, however I still have idle vty sessions, and I still cannot access the running config.
When I attempt to "sh run" I get the following:
Current configuration : 0 bytes
When I attempt to "copy start run" I get the following:
Destination filename [running-config]?
%Error opening system:/running-config (Device or resource busy)
There must be a PID locking the config somehow. Any other suggestions? I am obviously trying to avoid rebooting the router at all costs.
Thanks!
-Jason
07-02-2003 06:05 AM
what kind of box is it ? what is the code ?
07-02-2003 06:41 AM
2621xm, running 12.2(11)T8
07-02-2003 06:55 AM
or
07-02-2003 07:30 AM
Thanks man, next time I will search the bugtraq - it just usually times out on me.
I guess I will be updating the IOS :) It seems to be the first bug you listed here, as I did query that QoS MIB.
Thanks again!!
Cheers,
-Jason
07-24-2003 04:50 AM
I had a similar issue today and the post posted by Jaon solved my proble...kudos to jason
Tx
Ravi
