Webcast-Catalyst9k
Purple
if-index
Whats a quick way on a 6509 Sup720 to see the if-index number for a given port. Used to be easy on a catos box , having trouble finding it on IOS . Whats the command ???
Re: if-index
What IOS are you running?. ""show snmp mib ifmib ifindex" was added in newer IOS through the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCds71171
Purple
Re: if-index
Running 12.2.18SXD4 on the 720.
Re: if-index
Then you should be able to use "show snmp mib ifmib ifindex"
114
