IGESM in IBM Blade center
rajeshk200_2
Hi all,
Is anybody knows how to get telnet access to IGESM in IBM blade servers?
basically i need to enable trunking between this module and uplink switch.
Thanx in advance.
Rajesh
glen.grant
This done by the actual management module of the blade server itself , you actually telnet thru the blade server management module to the cisco switches in the blade server. Whoever is in charge of the blade server should be able to set this up and assign addresses for your switches.
