igrp/eigrp load-balancing - how many paths ?
Hi please somebady who knows - please advice.
how many equal-cost paths are supported by IGRP ?
how many unequal-cost paths are supported by IGRP?
how many equal-cost paths are supported by EIGRP?
how many unequal-cost paths are supported by EIGRP?
Gold
Re: igrp/eigrp load-balancing - how many paths ?
IGRP is dead, so 0. :-)
EIGRP supports as many equal cost paths as the RIB, CEF, and hardware limitations allow. On older images, with most hardware, this is 6. At some point, a fix was made to increase this to 8, which is the current top end. There are plans to make this 8, or even more.
There are some hardware platforms, I think some of the Catalyst series, that are limited to 2 in hardware.
Russ.W
what do u exactly mean by IGRP is dead . It is pretty alive and available in IOS 12.2
Gold
Yes, but it is currently being pulled from the code. I think it's out someplace in 12.3, but I'm not certain where.
Russ.W
197
