01-30-2004 05:26 AM - edited 03-02-2019 01:15 PM
Actally I am currently working on IGX 8410 with UVM card, In firmware Version 9.3.11. But unfortunatelly I have one UVM card which is not compatible with 9.3.11 and that UVM card is heaving E model with J software version(ENJ).
I tried to upgrade the software by downloading the patch from your FTP server.But all went fail. I am using windows not any UNIX OS. Could you pls help me to solve this problem. I will be very thankful to you.
Regads
Sudhir Singh
United Nations Logistics Base
Brindisi. ITALY
01-30-2004 12:04 PM
Sudhir,
Where did you see that Model E revision J for UVM was not compatible with 9.3.11 ?
Also what firmware did you try to load on the UVM ?
02-03-2004 07:34 AM
I checked the firmware compatibality on this link of the cisco.com
http://www.cisco.com/cgi-bin/Support/dspcds/home.pl
I was trying to download DMF version on the UVM card. because D model is compatible for Model E also.
Still I am looking for the help.
Regds
Sudhir
03-03-2004 02:24 PM
Sudhir,
I am not sure I understand what you mean by DMF version. UVM firmware models are available from Model A through E . So for a model E firmware, the file name would appear as DEX ( where X is the revision number). The first letter D merely indicating that this is UVM card.
Now please do paste a dspcds from your node here and I should be able to help you further. The image that you should be trying to download is DEJ. This should work on the 9.3.11 release.
If you are getting failures loading this firmware, please indicate the detailed steps that you are using and also the error messages, log messages etc that you are seeing.
Shajith
