Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IGX Firmware upgrade on WinXP
Hi All,
I would like to know if there is a way to upgrade an IGX firmware using a PC with Windows XP as operating system.
the SVLITE software can't work on this OS, so i hope that there is another software that can do it.
please let me know any news, links, forum and whatever you think could be usefull.
thanks a lot
Simone
Re: IGX Firmware upgrade on WinXP
Simone,
You can upgrade the firmware or switch software on the IGX if you have lan connectivity to the box and a tftp server and client installed on your PC, regardless of the operating system on it. Please check the following links from CCO that explain in detail how to do this.
http://www.cisco.com/warp/public/74/156.html
Thx a lot for your info, i'll try this way.
if there are other way to do it please let me know.
"ciao" from italy
94
