11-05-2002 03:37 PM - edited 03-02-2019 02:39 AM
I have ATM link but some times this is very Slow and received this message in the log
Oct 30 08:04:34.216: %IMA-1-MAILBOX_FULL: The mailbox for channel 0 on
IMA Network Module
n slot 2 is completely full. Message 0 was dropped.
Oct 30 08:04:34.216: %IMA-1-NO_MAIL_REPLY: Timed out waiting for a
response to command 0x
from slot 2.
Any idea
11-06-2002 08:47 AM
Can you post your config for both the phyiscal (int ATMx/0, int ATMx/1, etc) and the IMA PVC (int ATMx/IMA0)?
11-06-2002 11:46 AM
Sure here you have my configuration
interface ATM2/0
no ip address
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
ima-group 0
scrambling-payload
impedance 120-ohm
interface ATM2/1
no ip address
no atm ilmi-enable
ima-group 0
scrambling-payload
impedance 120-ohm
interface ATM2/IMA0
no ip address
interface ATM2/IMA0.1 point-to-point
bandwidth 1750
backup delay 5 180
backup interface Dialer1
ip address xxx.xxx.xxx.xxx 255.255.255.240
ip pim version 1
ip pim sparse-dense-mode
ip ospf cost 571
no ip mroute-cache
pvc 1/33
vbr-rt 1750 1750
oam-pvc 0
encapsulation aal5snap
service-policy output voip-policy-1750k
interface ATM2/IMA0.2 point-to-point
bandwidth 1750
backup delay 5 180
ip pim version 1
ip ospf cost 571
no ip mroute-cache
pvc 1/33
vbr-rt 1750 1750
oam-pvc 0
11-06-2002 11:49 AM
The following notes might help
Error Message
%IMA-1-MAILBOX_FULL: The mailbox for channel [dec] on IMA Network Module in slot [dec] is completely full. Message [dec] was dropped.
Explanation The IMA network module mailboxes are full and cannot accept any more requests.
Recommended Action Copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
11-12-2002 02:46 PM
This is a cosmetic bug when you are polling the devices via SNMP management through Cisco View or HP Openview. "MAILBOX" is the protocol used on IMA. You can open a TAC case and get a recommended IOS to fix the bug.
Bessie
TAC 800-553-2447
11-15-2002 02:17 PM
Well I've had similar problem. On my 3640 IMA card can have only four IMA groups and if you have phisical interface active some kind of internal IMA group is automatically asigned to it. When I shuted down unused phisical interface everything was ok.
