Implementation of network load balancing between two cisco 2610 rtrs
admin_2
Level 3
Level 3
I am trying to create a load balancing system between 2 cisco 2610 routers. they are connected by two T1 lines. serial 0,1 any assistance would be appriciated.
drolemc
Level 6
Level 6
For load balancing, you will need to have multiple paths to the remote destination, learnt via the same protocol. These routes should also be the most prefered in terms of it's administrative distance as compared to other routing protocols running on the router. You could refer to http://www.cisco.com/en/US/tech/tk365/tk80/technologies_tech_note09186a0080094820.shtml
