Incoming call issue between PABX and R3600 using ISDN QSig.
In scenario Siemens PABX is connected to r3640, using Isdn Qsig signaling. Outgoing calls are ok, but Incoming call (PABX to router), the router gives dial tone after the first number dialed, so the 2,3, and 4 digits are received trought a voice channel (B.
How to receive all digits trough the D channel as a setup isdn message?
1 REPLY
Anonymous
N/A
Re: Incoming call issue between PABX and R3600 using ISDN QSig.
Use "direct-inward-dial" under
pot dial-peer.
Since this is Qsig the digit may not be sent in block but in two seperate messages. For the router interface to understand this and wait for all digit before attempting a match you might want to inlude the following command under the D channel interafce se0:23 or 0:15
isdn overlap-receiving
isdn send-alerting
isdn sending-complete
The most important is "Overlap receiving" the rest are optional.
118
