Incorrect values for 5 minute intervals on 7206
I recently replaced a 2621 with a 7206 to terminate some point-to-point T1's. I use MRTG and thought I was having trouble with that until I got to digging. A rough ascii art sketch of what I have set up follows:
S1/1:0---------------S1/1:0
7206 S1/2:0---------------S1/2:0 UBR 7223
S1/3:0---------------S1/3:0
The UBR is showing the correct numbers for input/output where the 7206 isn't. For example, from the UBR:
Serial1/1:0 is up, line protocol is up
Hardware is Multichannel T1
Internet address is xxx.xxx.xxx.254/30
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 44/255, rxload 145/255
Encapsulation HDLC, crc 16, Data non-inverted
Keepalive set (10 sec)
Last input 00:00:02, output 00:00:00, output hang never
Last clearing of "show interface" counters 11w4d
Input queue: 0/75/0/16 (size/max/drops/flushes); Total output drops: 97
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 874000 bits/sec, 112 packets/sec
5 minute output rate 267000 bits/sec, 120 packets/sec
885111665 packets input, 3343608535 bytes, 0 no buffer
Received 0 broadcasts, 5581 runts, 9 giants, 0 throttles
6628 input errors, 166 CRC, 0 frame, 0 overrun, 0 ignored, 419 abort
765811165 packets output, 4216137704 bytes, 0 underruns
0 carrier transitions
no alarm present
Timeslot(s) Used:1-24, subrate: 64Kb/s, transmit delay is 0 flags
From the same interface on the 7206:
Description: OneEighty T1 #1 to Cliffs
Internet address is 216.187.180.253/30
reliability 255/255, txload 1/255, rxload 44/255
Encapsulation HDLC, crc 16, CRC 16, Data non-inverted
Last clearing of "show interface" counters 00:34:05
Output queue 0/40, 44 drops; input queue 0/75, 0 drops
5 minute input rate 269000 bits/sec, 123 packets/sec
219912 packets input, 56488882 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
244443 packets output, 5869325 bytes, 0 underruns
no alarm present
Shouldn't the output of the 7206 match the input on the UBR and vice-versa? FYI:
IOS (tm) 7200 Software (C7200-IS-M), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Any ideas?
Justin
1 REPLY
Re: Incorrect values for 5 minute intervals on 7206
Could be this bug: CSCds92548 (Traffic counters not counting packets.
From the debugging it appears the packet has indeed arrived and was switched/routed however the show interface counters do not appear to be updated.) 12.1(2)T was affected by this.
Counters in general have a few bugs on them (eg for acls, cef, ipsec, show interface, snmp etc).
Steve
87
