Community Member
Increasing Bandwidth on Frame Relay
We just increased our frame relay from 512 to 768 at one location and from 256 to 512 at another location. We have cisco 2612 routers with serial interfaces to our TSU/CSU 120. Do we need to do any configuration to our cisco routers to see the new channels that were opened? Any help is appreciated. Thanks. Robbie
Bronze
Re: Increasing Bandwidth on Frame Relay
If the router is configured to use specific channels via the "service-module t1 timeslots" command, you'll need to update this setting.
yes, you will need to configure 12 slots for 768 and 8 slots for the 512 k upgraded circuits..
Check this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/inter_r/irdshoap.htm#1032031
92
