inexpensive IP managed switch/hub/whatever ?
We have some very small unmanned remote sites with control type equipment, and they currently have unmanaged hubs for the site 'network'. We have occasionally had problems and wished for a hub or switch that has some management capabilities, minimally to reply to echo requests, perhaps up to an SNMP managed device. The boss says that the 2950 is a bit too expensive, and I say these remote sites are too small for them anyway (some are just electrical enclosures at the side of the road). Anybody got any good ideas for me ? A small 8 port managed hub or switch that you like ? Please let me know what products you would consider for this, I'll buy you a coffee next time you're in Saskatoon !
I've looked through the Linksys line, and at 3COM but their managed devices seem to start at 16 ports of rackmounted interfaces. Ideally we can find a 5 or 8 port standalone device.
Best Regards, and Thanks for ANY suggestions,
Dave
Re: inexpensive IP managed switch/hub/whatever ?
Hi Dave,
I think the Catalyst Express 500 fits the bill. See:
http://www.cisco.com/en/US/products/ps6545/products_qanda_item0900aecd80322b09.shtml
However, as they have a 1RU size, it may be too big, although cheap.
The 2940 switches are the smallest managed switch we sell. They may be of interest as well.
http://www.cisco.com/en/US/products/hw/switches/ps5213/index.html
HTH,
Bobby
*Please rate helpful posts.
Ditto. I think the 2940 fits the bill. You can get them for about $550 + shippping
Check out the SMC device www.CDW.com
SMC TigerSwitch 10/100 Standalone 8-port 10/100 Managed Switch
8-port 10/100BASE-TX Fast Ethernet managed switch
MFG#: SMC6708L2 $242.99
I've only used the SMC stuff at home, never had any trouble with it. It seems to be what you're looking for though.
Sean
170
